Adds a default gateway to the routing table.
| gateway | Specifies a gateway IPv4 address. |
ipv6Gateway |
Specifies a VLAN gateway IPv6 address. |
ipv6ScopedGateway |
Specifies a scoped gateway. |
| bfd | Enables Bidirectional Forwarding Detection (BFD) protection for
the route. Note: You must type this keyword before specifying a
VLAN.
metric |
Specifies a cost metric. If no metric is specified, the default of 1 is used. |
vr_name |
Specifies the VR or VRF to which the route is added. |
If no metric is specified, the default metric of 1 is used. If you do not specify a VR or VRF, the current VR context is used.
Default routes are used when the router has no other dynamic or static route to the requested destination. A default gateway must be located on a configured IPv6 interface. Use the unicast-only or multicast-only options to specify a particular traffic type. If not specified, both unicast and multicast traffic uses the default route.
The following example configures a default route for the switch:
configure iproute add default 2001:db8::1234:5678
Support for IPv6 was added in ExtremeXOS 11.2.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
